SSBB
Evening,
Following an issue with 'thumping' into gears, I removed the Gearbox valve body from my C220 cdi ('03). One valve at a time, I cleaned it with contact cleaner. All springs were OK, none broken so they were put back exactly where they came from. Each solenoid was removed, again one at a time, cleaned and put back. Likewise, the contact plate. Solenoids were all reading 8 ohms.
I now have a completely different issue
Firstly, the engine warning (little pic of engine) is on, Secondly, the C/S switch no longer works (stuck in S), and then when selecting drive or reverse it goes in with a huge thump and the car lurches forward or backwards.
I also only have first gear.
I thought it might be the ECU, so disconnected battery, one hour later, no gears AT ALL...nothing. Had some dinner and headache pills, and then tried again, back to the first issue. Only have first gear and goes in with a mighty thump.
Any Ideas....Pleeeease, does the valve body need to 'Bleed itself', how to get the engine light off?
I dont understand why so many issues....the valve body is very simple to remove and is not complicated in itself.
Regards
Shane
Regards
Shane
