johncook109
Hi there. I need help. Thought I would try under car lighting. I have designed light units to go in the plastic sill retaining plugs that run the length of the car. These will have clear plastic covers to keep the units dryish. The wiring looms will run inside the sills and into the cars interior through the front wheel arches. I want them to come on when the central locking is activated to open and off when locked also as the doors automatically lock at 10 mph they will not be on for long. There will be a 20 second timer in the circuit to cover any long unlocked periods. I was going to activate the operation of these lights by a relay energised by power from the central locking mechanism. Now my questions are. Is there anyone who could post the wiring diagrams (with colour codes)and door panel removal of the drivers front door. If wiring for some reason was not a workable way I could have the relay mechanically operated using the door locking mechanism. Alternatively I might use the fuel lock power as this would achieve the same ends. Any thoughts or comments would be appreciated. I will post the complete DIY project if and when it is do able.
