SavMan
Your "stock" file is also probably a remapped file as you were already mapped prior to fitting the pulley.
Has anyone tried to lay down a decent 0-60 in an AMG????
Dyno's are definitely not a waste of time and after having a few Pulley conversions done in previous cars, real world increase is only about 20hp-30hp, which your not going to feel
3.70 secs E55 Estate
[YOUTUBE HD]eW7hDsgNb48[/YOUTUBE HD]
Trax 2012 - 3.7 Seconds Mercedes 0-60mph - YouTube
Has anyone tried to lay down a decent 0-60 in an AMG???? Mapped or not they are not exactly the most tractable cars, so in my estimation a 0-60 on one of these is a waste of time. You should be able to feel the difference with a pulley / map just in the way it pulls in normal driving, albeit you will not be able to quantify the exact difference.
If the OP fitted the pulley first then the car should feel quicker without a map, with a map it then just optimises fuel / air / boost so should then give another step change. Done separately it might not be dramatically that noticeable, other option is that the map isn't loaded correctly or something else is wrong...
To the OP, just get in touch with Jerry (which is what you have done) and let him advise.
0-60's are pointless Paul, don't ya know!![]()
What does this tell you?
We should all go to Vmax instead??yes/no???
It tells me something I already knew; once you're under 5 seconds then it costs thousands of pounds to shave tenths of a second off a 0-60 time.And just so you know Paul's 3.7 to 60 was done on slicks, the car has well over 100bhp more then the standard model, this was " only" 3 or 4 tenths quicker then a standard E55. What does this tell you?
Lol, yes Vmax is better for sure! Ricky we should tell Craig to drop the Vbox and fancy timing equipment and just spend 20 pounds on a stopwatch!![]()
Correct.
To measure a difference in power from an ecu and pulley tune on the op's car yes, it's actually stupid.
It doesn't matter if the car feels no different from a standing start or between say 40-70mph, as long as the dyno says there is more 'power', that's all that matters then...
lopes80 said:Sir I don't think you have driven a supercharged AMG Mercedes let alone one that's had a pulley and ECU, if you did you would know that they have huge torque and very difficult to launch, add more boost and you have an even bigger problem, hence why one would have a very hard time noticing the difference on a 0-60 run on the road with a stopwatch, ie pointless, that's my argument nothing more nothing less.
Didn't realise I was, I'm just trying to save the OP a few quid. If you find someone 'disrespectful' because they challenge something; that's your problem, not mine.I don't know why you are being disrespectful
information and advice is what the OP is after you have turned it into another pointless thread.
okay on the euroflash software I have got the options of either factory flash which will be a unmodified map and also a performance flash , both feel exactly the same and others say after having this done there should be a massive difference there just isn't .I have done a few pulls in 3rd gear and I cannot tell any change really between the 2 different settings . i have now replace the intercooler with a second hand unit that was pressure tested and the car hasn't used any coolant now for the last 3000 miles so its not that i didn't change the pump though , don't get me wrong im not saying the car is slow and just not really feeling the benefit of the pulley & tune like i was expecting . the only thing i can think is my car already had been mapped by a previous owner supposably so when i added the pulley i got a small gain but but when i got the eurocharged map it was just replacing 1 tuned file for another 1 so it was a bit hard to tell the difference. hopefully eurocharged will get back to me today im hoping something minor is not right because i want to fell a massive difference like everyone else has
