Question about Mercedes 270cdi injectors
Discussion in 'Parts, Maintenance & Servicing' started by Snoop108, Mar 19, 2017.
  1. Snoop108
    Snoop108 New Member
    16
    Mar 11, 2017
    Car:
    Mercedes c27cdi
    Hi folks, I need to order injectors for our Mercedes W203 270cdi 2002. Its now getting a little long in the tooth, and usual faults are beginning to surface.
    After suffering from the dreaded saddle bag fuel tank syndrome, I have replaced the fuel filter (Merc OE), all plastic fuel lines, and resealed the high pressure fuel pump just in case (wasnt showing signs of leak, but was corroded). Im now looking at replacing 2 injectors due to leak off, but have noticed that I already have 3 re manufactured injectors already installed, and two originals. My question is that they have different part numbers, the 2 original injectors are A6130700687, and the 3 reman injectors are A6130700987. What is the difference? Is the reman injectors a later updated version?
    Thanks in advance, David
  2. OP
    OP
    Snoop108
    Snoop108 New Member
    16
    Mar 11, 2017
    Car:
    Mercedes c27cdi
    Any injector boffins out there this eve?
  3. bob6600
    bob6600 MB Club Veteran
    5,779
    Jan 3, 2013
    Car:
    AUDI S8 V10, S210 E320 CDI (R.I.P.)
    More than likely a superseded part. I can check the part numbers in the morning. If you have a reg or a Vin I can give more accurate numbers
  4. OP
    OP
    Snoop108
    Snoop108 New Member
    16
    Mar 11, 2017
    Car:
    Mercedes c27cdi
    That would be much appreciated, Thank you
    reg KC02VDF
    vin WDB2032162F309599
  5. Tigger
    Tigger Hardcore MB Enthusiast
    246
    Aug 27, 2003
    London
    Hi David,
    Bob's hunch was correct.
    A6130700687 was the original part number which was superceded with A6130700987
  6. grober
    grober MB Club Veteran
    27,600
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    If I have got this correct :confused:
    A 613 070 09 87 the second last two [in bold] from the last two nos are the revision number and usually the higher the no the later the revision??
    Sometimes the number changes completely as it comes from a newer model with a different first 3 nos [ 613 ] but the group no usually stays the same e.g. [070]
  7. bob6600
    5,779
    Jan 3, 2013
    Car:
    Agreed, any of these two numbers will do. If you can source the newer one then great but the original one is fine
    Technically I would say yes but I'm sure I have seen some exceptions
  8. OP
    OP
    Snoop108
    Snoop108 New Member
    16
    Mar 11, 2017
    Car:
    Mercedes c27cdi
    Awesome folks, thank you for your help :)
Share This Page
