Hi I'm about to fit some E Class Sport 18's to replace the existing Avantgarde 17's.
Does anyone have any idea if I can re-use my existing bolts?
If the offset is the same should be fine
The offset has got nowt to do with bolt length. It's all about the thickness of the rim centre. You can only offer one of your bolts up to the new rim and see by how much it projects out from the rear. Compare that your old rim but approx 25mm is about right.
