GavinP
Anyone one know what the silhouette with a number (1 in my case) next to it on three quarters of the way across the top edge of the COMAND display means please?
It's a bit hard to guess without knowing which menu screen you are referring to, but it could mean there's a map update available. The car will allegedly download it via the installed sim - if you have about three months to spare. You could check on the Mercedes Me portal to see if there are updates for your car. I always download them onto an SD card using my computer, and then let the car update from the card - it's a lot quicker.
It is the current profile you are using. You can set up three different profiles in COMAND. The number denotes which profile you are using.
