wwgraham
I recently bought a second hand Comand unit Part No: A 208 820 34 89. The car presently has a standard Audio 10 (Cassette version) and 6 stack CD player in the boot It is a Y2000/facelift model and so as I understand it all I need is the following to install:
- Audio10 plug adapter to enable the connection of the COMAND to the exisiting wiring
- Antenna to fit under dash
- Navigation CD
To fit I believe I need to:
- tap into the correct speedo wire
- Cut away the divider in the dash to enable fitment
- ensure the COMAND is reprogrammed with the correct engine size/wheel size etc.
Can anyone confirm if I am correct in my assumptions, together with any additional parts or information I may require? also how do I physically secure the comand in the dashboard?
Finally can anyone recommend san installer? I'm based in Edinburgh but would be willing to travel if required.
Many thanks in advance
Will
- Navigation CD
Will
