Hi
2010 E250 S212 wdd2122032 om651
I intend running some mannol shave foam style cleaner with the long hose attachment through the aircon ducts and evaporator.
Is there a way of checking if the evaporator drain tube is blocked without getting under the car and removing the panels from the underside?
Would there be symptoms if there was a blockage?
Thank you,
D.
MANNOL Air Conditioner Cleaner
www.mannol.de
Thank you,
D.
