I've swapped out the idler pulley as the bearing was a bit gone.
Got a damper too but the lower bolt won't retract far enough with the water pump pulley in the way.
Query is this, is the 8mm allen / socket screw that holds the viscous fan coupling to the water pump a LEFT hand thread?
TIA
TIA
