timwood2000
- Feb 17, 2008
- Location
- Bromley, Kent
- R320 CDI SE LWB '07, BENTLEY CONTINENTAL FLYING SPUR MULLINER '06, FIAT 500 LOUNGE '58 & BMW R1200RT
I have had my R320 for 14 months now and I love it (and I know that the R class is not that popular).
I now have a broken rear side opening rear window for the 3rd time. The rear side windows open outwards, but the window is attached to the opening mechanism with glue. The problem arises when I close any of the doors - because there is nowhere for the air inside the car to go, it ends up forcing against the most vunerable part of the car - in this case the rear vented windows.
The first time, it was replaced under warrant at Vikings, Canterbury, the 2nd time it was the other side window, and MB Chelsea replaced that one, now, the first one has gone again.
I know it will be replaced under warrant, but apart from the security issue (you can pull the window open as it not attached to anything), it is the inconvenience of having to (a) go to the garage so that they can see it and then (b) having to go again to have the job done. It just seems to be a design fault.
Have any other R class or GL or ML if they have the side opening rear windows had the same problem - or is it just me!
Thanks. Moan over.
Thanks. Moan over.
