golden1245
- Sep 6, 2011
- 1999 C230K Sport
I just took my car to a shop to have the lower ball joints and lower control arm bushings replaced and the car drives incredibly well now, almost like brand new. Very solid, all the shimmy-ing, violent steering wheel shakes over bumps and holes, high speed instability, wandering, excessive leaning, are all gone.
There was so much play in the ball joints after they took them out, no wonder they were causing problems. With the old bushings, the whole control arm also moved very easily with a push of a crow bar.
I know yall's maybe thinking where I'm going with this post, but for anyone having those symptoms I described, definitely look into replacing the ball joints and LCA bushings.
The only issue I noticed is that the front of the car is riding a bit high and even after a few hours, has not settled down. Could the springs, not be seated correctly or the shocks not tightened correctly? I noticed that the repairman tightened the lower shock mount while the car was in the air, but did not tighten it when it was back on the ground...
Or is the suspension higher because of these new parts? Thanks for reading
