All
Had a tyre blow go yesterday on the M25, and stuck the hazards on while I was replacing the wheel.
Driving into work later, noticed I was getting some honks and a couple of nice hand gestures and realized the indicators were not working.
Quick check of the fuse map, and everything else on the indicator/hazard fuse is fine, so that's not the issue.
I have, once, got them to work with some repeated flipping of the hazard switch and on occasion I can see a faint glow under the hazard switch when I switch them on, but no flashing indicators.
So am I looking at a likely switch replacement, or does this sound like a relay issue ? If it's the relay, I'm reading either that it's in the switch, or behind the dash. Can anyone confirm where it is on my model ? The CD of factory manuals I have shows no relay at all, which I'm sure is bunk !
