Djet or Kjet? try reading this rather lengthy thread on a W115 coupe restoration for some links/explanations
Mercedes W114 250 Coupe - help!
or try this set of videos.
The new metering unit is a refurbished original, I've returned it once and they say it is working perfectly. However if I put the old one back on the car fires up right away.On the K Jet system there is only one user adjustment, the fuel mix screw, everything else is fixed, have you checked the WUR is functioning properly, all the procedures for test are in the workshop manual?
If you have bought a re-manufactured fuel distributor it should already be tested and working.
PS the pressure from the fuel pump should be more than 5bar.
