R107 sl280 fuel pump relay
Colgate
Essex
SL 280, S 320
Can anyone advise me on the location of the fuel pump relay please? Also if possible a photo of what i am looking for..... Got the old girl running by powering up the fuel pump directly so just need to suss out the relay
Many thanks in advance :thumb:
Col
Col
You're looking for something along these lines:
euromercwebstore: Fuel Pump Relay
On the bulkhead or footwells?
Above the fuses, drivers footwell. Remove the dash undertray for access. Bridge out pins 30 and 87 on FPR to prove it faulty. Pump should then run continuous with ignition on.
Thanks Druk, was as you said. I have taken the relay apart and there is signs of water damage. Will try and clean up the contact etc as price from mercades is £180!
i recently did this. under dash like druk says....
i re-soldered mine and it now works again
2nd hand is much cheaper and £50ish from europarts i think for 6 cylinder, have some spare if needed
