Davidt
I'm new to this forum and so I hope I have posted in the correct area - forgiev if this is wrong.
I have a 1979/80 450 SLC which has two problems that I hope someone can help me with.
1. The delay wipe/intermittent position has stoped working, it occasionally failed to wipe on intermittemt but now really has failed altogether. Also at the same time, the 'self park' no longer works. I assume that the delay wipe simply uses some relay to 'trigger' the wipers and the self park then 'parks' them until they are triggered again.
So my guess is that perhaps it may be the self park that is the primary issue and this is causing the delay wipe from operating?
2. I am having a locking - or rather an unlocking problem - the central locking works fine on doors, boot and petrol flap. Unlock it shortly after locking and all unlock. Leave it a while, and attempt to unlock it and although the doors unlcok, the boot remains locked. On starting the engine, then 'unlocking' using the fob and the boot unlocks.
I appreciate I have a leak somewhere in the system, but anyone any idea where I start to look for it?
Any help, very much appreciated.
Regards
David
Regards
David
