R129 1991 500SL Turns Over But Will not Fire
Discussion in 'Electronics' started by GregE240, Aug 31, 2016.
  1. GregE240
    GregE240 Active Member
    952
    Dec 30, 2002
    Northamptonshire, UK
    Car:
    1990 500SL
    Hi there
    Been a while! I hope everyone is well?
    I've got a problem with my SL - I suspect it is immobiliser related but hope someone can offer me some advice. I went to start my car earlier and as it has been a while, I let the immobiliser kick in so the engine would turn and not fire. I then usually lock and unlock the door by sticking a key out the window, but this time - nothing.
    I have bought new batteries for the key - its not that. I've disconnected and reconnected the battery - same (battery / car has been on CTEK conditioner and turns over engine easily). I've checked the OVR fuses - look fine.
    I'm at a loss - any assistance appreciated. I'd call the AA as I'm a member but I suspect they won't have a clue, hence asking for advice!
    Many thanks
    Greg
  2. RichardF
    RichardF Active Member
    547
    Aug 24, 2013
    Car:
    Sl 320
    Is it an aftermarket immobiliser? They usually isolate the fuel pump.
    You might be surprised @ the AA, many of the guys are "time served" and used to dealing with stuff like this. A while ago I worked for a main dealer, they liked recruiting roadside assistant guys into the workshop, more experienced @ problem solving.
  3. OP
    OP
    GregE240
    952
    Dec 30, 2002
    Car:
    1990 500SL
    Hi Richard - no, its OEM with the green and red lights in the doors and bootlid button.
    What is does do is kill the fuel pumps, as I don't hear them pressurizing when I turn the key, nothing.
  4. d w124
    d w124 Hardcore MB Enthusiast
    12,379
    Dec 30, 2008
    london
    Car:
    w124 3.6AMG styling E320 S124 Lorinser styling
    Do these have have ovp relay
  5. OP
    OP
    GregE240
    952
    Dec 30, 2002
    Car:
    1990 500SL
    Hi - yes, checked both fuses, both fine
  6. d w124
    12,379
    Dec 30, 2008
    london
    Car:
    It might be the relay itself.Fuses on these hardly ever go
  7. Dec
    Dec MB Enthusiast
    4,475
    Jul 28, 2004
    Car:
    C180,A.
    Try, a few times, to synchronising the remote key fob.
    Can you see a Blue/White light through a digital camera when button is pressed?
    Dec
    [​IMG]
    [​IMG]
    1 person likes this.
  8. RichardF
    547
    Aug 24, 2013
    Car:
    Sl 320
    Try reseating the connectors for the locking system and alarm with some contact cleaner.
  9. OP
    OP
    GregE240
    952
    Dec 30, 2002
    Car:
    1990 500SL
    Where is all of that, Richard?
  10. RichardF
    547
    Aug 24, 2013
    Car:
    Sl 320
    It's the units in the boot on the drivers side above the battery, doing this rejuvenated my alarm/immobiliser.
  11. OP
    OP
    GregE240
    952
    Dec 30, 2002
    Car:
    1990 500SL
    I'll give that a go. Many thanks!
  12. rorf
    rorf Active Member
    424
    Jul 23, 2011
    Cape Town, South Africa
    Car:
    2000 SL320 v6, 2001 CLK320
  13. OP
    OP
    GregE240
    952
    Dec 30, 2002
    Car:
    1990 500SL
    You're a star sir! I shall investigate!
    Many thanks!
  14. IBN
    IBN Active Member
    77
    Dec 15, 2006
    Northern France
    Car:
    W129 300SL
    Hi I had a similar problem with my 300SL last year and it turned out to be a faulty MAS Unit.... dealer wanted €800 for a new one, bought a second-hand one off someone on this site and it fixed the problem.
  15. RichardF
    547
    Aug 24, 2013
    Car:
    Sl 320
    A good point, have you tried reading the codes?
  16. OP
    OP
    GregE240
    952
    Dec 30, 2002
    Car:
    1990 500SL
    Haven't got anything to read them with.
    OK, so tonight, I have:
    - bought contact cleaner;
    - removed and cleaned the connectors off both the black and white boxes adjacent to the vacuum pump in the boot.
    Sadly, no good. Richard also mentioned in another thread pulling fuse 5 and trying to start the car. Sadly, no good either.
    Symptoms remain:
    - at ignition position 2, the fuel pumps are not priming as they usually do;
    - both the remote keys have stopped working.
    Any other ideas? I am calling Green Flag tomorrow to get them to look at it, though I suspect a low-load to a specialist may be the order of the day....
  17. RichardF
    547
    Aug 24, 2013
    Car:
    Sl 320
    Have you tried locking/unlocking manually?
    Worth googling code reader, it'll cost you pennies to build. And although the info is a bit limited it'll still prove invaluable in future trouble shooting.
  18. OP
    OP
    GregE240
    952
    Dec 30, 2002
    Car:
    1990 500SL
    Locking / unlocking manually works, but only the door the key is in. The vacuum system does not unlock everything / central locking.
    Is there a stick for this code reader? And where is the connector? Is it near the fuses or over near the ECUs?
    Thanks for your help with this Richard - much appreciated.
  19. alabbasi
    alabbasi MB Enthusiast
    1,483
    Feb 18, 2008
    I'd start with the basics. Are you getting fuel to the engine? Is there a spark?
    Might be a good old fashioned non immobilizer problem.
Share This Page
