Blade parks on driver side on UK car.
Using your picture above and if there were no alignment marks you would do the following;
=Remove the right side bolt and lift off the short arm beside the ball joint
=Plug the motor into power and run it for a few seconds
=Switch off the motor at the stalk switch, the motor is now parked
= Unplug the motor
=Slacken off the left bolt but don’t remove it from its shaft
=Loosen the arm at this bolt with the screwdriver like in above picture
=Move the wiper arm to where you think it would rest in its park position on the car.
=Reattach the short arm beside the ball joint
=Reposition the other side while keeping the wiper arm/hub where it should be parked on the screen
=Retighten both bolts
=Test on car
Dec
= Unplug the motor
=Test on car
Dec
