Marcosal
I have a 1999 320SL that has a passenger door window that is tilted slightly too far back when closed and is catching the trim when opening and shutting the door. The automatic rise and fall works perfectly and give the correct clearance at the top so that is not the problem.
I have found instructions on how to remove the door card and understand that there is a way of adjusting the fore/aft tilt of the window. Is my understanding correct? If so, can anyone help me to identify where, in the door mechanism, I make the adjustment.
