Good morning, My aerial on the R129 stopped working one day and I’ve decided to have a go at seeing what’s wrong. I’m no expert at all so google a bit and used some info from threads on the forum. Now I’m stuck!
I removed the aerial, there is power to the wire leading up to the aerial as far as I can tell and then to the aerial itself but no noise or movement. Below is a pic of the aerial removed and the wires which I have power to.
I placed one part of the tester to an earth on the car and then tested each wire, is that right, the only one that had no power was the brown one? Should I just buy a new motor or am I missing something?
I also removed the black box on the aerial that the wires go into and tested the other end and both terminals also showed power to them
