Doodle
5sp box is a slightly more spirited to drive with the extra ratio and electronic control, and the Motronic gets rid of the LH-Jetro's distributors.
Timing chain I would ignore until it actually needs doing - you'll get plenty of warning.
Leads will probably be tired if original. Caps and rotors do as required.
Springs will be fine unless you want to lower/uprate, but new shocks and bushes will make it feel fresh and taut. Not cheap though.
I presume by flexi-disc you mean driveshaft donuts? Again, do them as and when needed.
