R129mine
Hi
Last couple of weeks i have noticed when pulling at door handle on driver's side (from in our outside) you have to slightly try and open the door for the window to lower itself a few cm's so you can fully open the door. I tried resynching the windows checked fuses but made no difference. I did have a low battery issues a few weeks ago where ESP and abs lights remained on while driving and the car was stuck in limp mode but I have had the battery on a charger in the garage for last week and that problem has now gone. The fact that the windows do lower but not immediately indicates to me it is something to do with the sensor/mechanism in the door which fails to recognise the door is being opened. If I lower window before opening the door there is the same delay before I can open the door.
Do you think this is something with door opening mechanism?
Cheers
Cheers
