Hi Any help over knocking problem can't locate it, When going over bumps in the road at speeds of less than 40 i get a metallic knock/ rattle from the front corner of the car. Ive had the roll bar bushes changed , idle bush linkage and engine mounts changed, still no change. i removed the front shock and top mount off to check for metal to metal rubbing all seems fine. sound best described as when you drive over a worn manhole cover that is loose fitting with that metalic clunk
but under slight breaking it tends to go. brake callipers also appear in good order.
look forward to any pointers out there
