Dougcsv
- Jan 7, 2019
- Location
- DL12 9SU
- '93 500SL, BMW 320d MSport, Ford Ranger, Bond Bug
Hi I have a 93 500SL - the passenger side window doesn't work (drivers side is fine) ; if I push the centre console window switch either way I can hear the relay in the roof module click. I've stripped the door and removed the motor which was completely clogged up in the gearbox....I cleaned it all out and reassembled and tested it connected direct to a 12v battery and it runs fine fwds and back. On connecting it back up to the wires in the door it does nothing. Without it connected i get a few volts at those wires at the door when I push the centre button but only for a few seconds. Any thoughts...???
