Hartzpartz
- Feb 26, 2005
- Location
- Sompting, West Sussex
- E200 W210 (ex 500SL, ML55 and 190 Cosworth owner).
.....actually, looking at your wiring diagram (Thanks to Stats007) it appears that all the switch does is provide an earth signal for the ADS ECU. I assume in this case, the switch has an earth wire going to a "console earth" mentioned on the diagram. A bad earth may explain why the LED/illumination flickers when the ignition is turned off (feedback through another circuit in the ADS ECU?).
Has anyone seen this earth wire or earthing point behind the console? Would be handy to know if the switch earths behind the panel before I take it all apart!
Would be excellent if anyone knows where connector "X33/9" is located also as this may be causing the problem.
