SL60 3-piece AMGs were 18": 8.5 x 18 ET25 front, 10 x 18 ET25 rear.The wheels are 8.5" x 17" ET18 front and 10"x17" ET17 rear
KLP 92 said:Standard AMG fit on a pre 1995 SL. These wheels also fit the W126 series.
Over the time the R 129 “SL” have been built, Daimler Benz replaced in June 98’ the Double Twin cam 32 Valve engines oft the M 119 series and the Inline Six’s by V 90° 6 and 8 Types with a single cam per bank and three valves per cylinder. {Type M 112 an M 113}.
All the AMG R 129 built types used the same Identification code of the basic Daimler Benz car design.
The “SL 60” was based on the “500 SL” {R 129.066/.067}, a car, originally fitted with an 4.973 cm³ engine {M 119.960/M 119.972/M 119.982}. There have been built three different AMG Versions of the “500 SL”, but the major changes are the same.
The original crank was replaced by the crankshaft of the M 117.968 {“560”}, means the stroke was increased to 94.8 mm {3 ¾ in.}. The bore was increased to 100.0 mm { 3.94 in.}, so the engine capacity reached 5.956 cm³. Inlet and Exhaust channels of the cylinder heads were extended and polished. AMG exhausts has been fitted.
”500 SL 6.0 AMG”
First conversion to 6 Litre, based on the R 129.066 fitted with the M 119.960 KE engine.
These with Bosch KE engine control reached 374 hp @ 5.250 rpm and a maximum torque of 550 Nm @ 4.000 rpm.
They used the same Four speed automatic transmission {722.353}, Differential ratio and brakes as the 5 Litre cars. The tires, mounted on three-piece AMG rims {8 ½ x 17 ET 18 – 10 x 17 ET 17} have a size of 255/40 ZR 17 – 255/55 ZR 17.
This car have been built between September 91’ and August 93’.
”SL 60 AMG
The second series, built between September 93’ and December 95’ used the M 119.972 LH engine with Bosch LH engine control. Those engines, as those of the “E 60”, reached 381 hp @ 5.500 rpm. {580 Nm @ 3.750rpm}. This series still uses the same Front an rear brakes as those fitted on the serial “500 SL”, also have been changed to a larger diameter.
The automatic gearbox was replaced by the 722.364, still having 4 Speeds.
”SL 60 AMG
The last series was built between have been April 196 and May 98.
Now the M 119.982 with Bosch ME engine control was converted, but the output was unchanged. The gearbox was replaced by the new five speed automatic transmission, rims have had 18” diameter, the size of the tires reached 245/40 ZR 18 – 275/35 ZR 18.
AMG Aerodynamic Body kit have been fitted to all official converted cars.
Of all series have around 300 cars been built.
Kind regards
Otfried
SportsCoupeRich said:beautiful looking wheel though...
BTB 500 said:They are great wheels, I might be seriously tempted if I saw a set that were the correct size/offset for my car.
Flash said:The ones sold could easily fit your with a bit of modding...
aka$h said:If in not mistaken, to increase offset you have to do the opposite of adding spacers, so shave off a little off the centres. It can be done though, Im getting a set of these on my CE, 10" on the rears!
