I am getting an intermittent starting problem with my SL320 V6.
The first once or twice it happened I thought it was my fault letting the key go too soon even though I know it should automatically crank the engine until it starts even after letting go of the key.
The starter motor engages for a split second, the rev counter needle flicks 3/4 of the way around the dial as the starter disengages before the engine turns and fires. Sometimes it will fire immediately on the next turn of the key or sometimes it will repeat the non starting 2 or 3 times before it will fire. It will then be fine for several days before this happens again.
I would like to get to the bottom of this before it gets worse and I'm left stranded, so any help pointing me where to look would be appreciated.
thanks in advance.
thanks in advance.
