The carpet in the rear drivers side footwell is soaked. I quite certain that it isn't coming in through the roof or door seal as this is the only area that is wet. The car is normally parked on slight slope and when I moved it this morning and parked it on level ground, I noticed that there was water running from underneath the car on that side On closer inspection this water was running from what I can only assume are drain holes. Can anyone explain what is causing the problem and advise how to sort it?
Cheers,
Dan
Cheers,
Dan
