TJJ
Morning All.
Would anyone happen to know where I can find dimension details for the Pitman arm and idler for an R170 please?
Symptoms.
When in a straight line the car drives fine. When turning to the right everything also seems fine. When turning to the left the left front wheel scrubs badly. The harder you turn it to the left the worse the scrubbing gets. My suspicion is that someone has previously fitted the wrong idler causing the Pitman and idler arms to be different lengths. I suspect that the tracking has been adjusted such that in a straight line everything is in the right place, but as soon as you turn the wheel the geometry goes wrong. The problem is, it's obviously happened a long time ago so everything is equally weathered. I can't tell whether it's the Pitman arm, the idler or both that's wrong.
Open to suggestions of anything else it might be but above are my thoughts. Any help gratefully received!
Forgot to say, it's gone through the last 3 MOT's like this as well....
Symptoms.
