R171 Roof/Rear Quarter Window Issue
jimmymidnight
Ely, Cambridgeshire
W221 S350L
Hello, My mother picked up a 2007 SLK280 at the weekend and everything was fine until we put the roof back on and the drivers side rear quarter window didn't close all the way, you can pull it closed a bit more but obviously that's not ideal!
Anyone know of this being a common fault and/or how to fix it?
jaymanek
Nuneaton Warwickshire
Its likely the battery has been off and it hasnt been set up properly.
- Close roof, windows etc.
- disconnect battery for 5 mins
- reconnect
- sit in car with doors closed
- with ignition on, take the windows up and down 3 times each. hold at each end for a second or so.
- run car and go lock to lock with steering 3 times.
jaymanek
Think you should be ok, just the steering angle sensor which I have outlined above.
OP
OP
jimmymidnight
jimmymidnight
Ely, Cambridgeshire
W221 S350L
Sorry, i tried this but its still not closing properly on the drivers side. Any other suggestions?
