I'm trying to remove the passenger seat cushion from my '05 SLK to get at the SRS seat sensor. I recently replaced the heater motor and fan, which entailed lying half-on the seat for an extended period, and next time I started the car the SRS warning light came up. My iCarsoft says it's open circuit to the seat sensor. I can cancel the stored code, but it comes back immediately the car is started up. I suspect I've displaced the wiring under the seat when lying on it. Buckling up the seat belt makes no difference.
Three questions, then. Firstly, could the culprit be the front SAM, which has been playing up recently?
Secondly, I assume the sensor loom is the yellow one going up to near the centre front of the seat cushion?
Thirdly, the yellow loom has a very strange (and small) yellow connector at the end which goes to the plug unit at the front of the seat base. I've never seen one like it, and I can't work out how to release it at all. Does it pull straight out, or slide off sideways, does anybody know?
