reflexboy
I appreciate the weather has changed for the worse now, but the condensation in my partner's SLK (R172) is really bad. The carpets, foot wells and boot are all bone dry and the pollen filter is also bone dry. The outlet drain from the pollen filter box is clear also. When putting the Thermotronic to the max setting to clear the windscreen it takes an age. The condensation is literally running down the inside of the windscreen. The AC seems to work OK and I have cleaned and treated all the door, roof and boot seals. Is there anything else I need to check? Is there a guide to checking and locating where the water drains are on an R172, or is this just a 'trait' of the car?
