gramey
So the first problem since I bought my R230 SL350 10 months ago has appeared, I left home and everything was fine for the first 8 -10 miles. I then came to a roundabout where I had to give way to an oncoming car. When I went to pull away the gearbox hadn't changed down and I crawled away slowly building up speed.
I continued my journey and there was traffic ahead, but if I dropped back a bit and depressed the accelerator it wouldn't change down, even if I hit the kick down. If I eased back but held the accelerator around half way sometimes it would change down but mostly not.
I pulled over and turned the car off, waited a few minutes and then started again, I accelerated briskly and the up changes appeared to be fine.
The only difference now was that the engine management light came on but it still wouldn't change down on the throttle. I tried manually shifting it down on the gear stick and it would change up and down fine but still the same if I put it in drive.
When I returned home from my fathers the car appeared to be fine again, kicking down when I wanted it to but the engine management light is still on. I shall see if my local indy can plug it in tomorrow and diagnose what the problem is but does anyone know what the likely cause would be?
