koopz
Just before Christmas I got the dreaded red ABC warning. Suspension went very floaty and the button to raise and lower stopped working. Got the car home and plugged it into SDS and had System Pressure Too Low and Malfunction in Pressure Supply faults. Pressure was reading around 110-115 bar (I believe it should be about 180). Checked the fluid level and it was low, so I ordered some fluid and waited. Got it topped up yesterday morning to the correct level and straight away the warnings went away and the button to raise the suspension was working again. Checked the level again this morning and it's still in the same place, so if it is leaking somewhere it's not a catastrophic leak. I haven't checked the pressure reading yet, and the car is not currently being driven.
The thing that is really confusing me though is that when I check the fluid level on the dipstick with the engine off, it's in the right place (on the high mark). But when the engine is running it's way too low - right at the bottom of the dipstick. Turn the engine off and wait for half hour before measuring again - back to the high mark. Where could the fluid be going while the engine is running? Has anyone experienced this before?
