Tritonxv
Hi, I've had my 2003 Sl500 since 2017 and it's never skipped a beat. However, I stupidly tried fitting an LED bulb to my passenger sidelight last week, predictably it flashed, put back the original bulb and the car went dead (after a brief electronic consumer batt offline warning) The leisure battery had died (I was aware it was getting old) so I bought a replacement, everything seemed ok but noticed I now have no power to my drivers door controls so no drivers window either (central locking fine plus massage seat works and the seat controls on the actual seat tilt it forwards and backwards) but also no folding mirrors?? Drivers window won't drop for the roof either or raise after locking car.
I've check the fuses under the hood, behind the drivers seat and the pre-fuse box in the boot so far (not passenger footwell) I have an icarsoft v3 scanner and that says no faults but it skips the drivers side control module when I run a test.
Any suggestions and please be kind...I know I've been an idiot causing problems that weren't there!
