R230 issue
PhantomF4
Somewhere south of Iceland
R230 Thulite Red
Has anyone replaced these filler pieces either side of the rear window?
Mine seem to be delaminating and are letting the look of the car down.
NJSS
Near Petersfield, Hampshire.
2011 SL 350 Fire Opal Red|||2016 Land Rover Discovery|||1973 MGB GT V8|||1959 MGA Roadster
They can be replaced; I believe that the part numbers are are A 230 792 03 30 and A 230 792 04 30 cost over £130 if you can find any, and I can't.
The alternative is to remove them and have them sprayed or even wrapped, at a much lower cost.
Open the roof so the side roof C pillars are roughly vertical, there is a small locating pin about 1/2 way down the edge of the plastic cover on the window side, just wedge the cover up slightly, then with a hammer and wood wedge tap down on the plastic cover top edge about 1" and the cover releases from the locating lugs and comes off. Install is reverse of the removal process except you tap from the bottom with the hammer/wedge. A tip is to make sure all lugs have located before you do the final taps otherwise you will get a bump where the lug may not locate correctly, also don't go too far up or the locating pin wont slot in place. I also found closing the roof a little helped with taping the cover back in place.
Good luck.
NJSS
John757
Surrey UK
E350CDi Coupe AMG (2010) , G Wagen G280GE Short (1990), SL55 AMG (2003)
I ordered one.. it took 1 year, to arrive from MB .. not fitted it yet.
NJSS
John well done !
Can you confirm that I quoted the correct part numbers, as I have tried to order them without success. I am concerned that it has been suggested that the part numbers I quoted above may be for pre-facelift R230s, so if anyone is shopping around & finds a pair this needs to be checked.
It would also be very helpful to know when you ordered them, from whom & what you paid for the pair.
Thanks in advance.
NJSS
John757
Surrey UK
My Car is 2003 R230 this part is for UK passenger side, rear window, side trim... the part has been updated and a new mounting plate has to be used as well.
£130 each sounds right, I think the mounting plate was about £50.. waiting on an email for other side part number from my contact at MB.
mounting plate
trim
OP
OP
PhantomF4
PhantomF4
R230 Thulite Red
Thanks guys. I think I’ll go for the DIY paint solution. Can anyone suggest what the best primer and topcoat paint would be?
If I screw this up I’ll go look for somewhere to get them wrapped instead.
Cheers
cbxpete
Devon
SL55AMG C350CDI estate
Cheers
Be very careful how you remove them, they get very brittle and break easily.
Pete.
John757
Surrey UK
Got the up to date prices;
Mounting plates;
A2307900304 (*Left side -as you look towards the front of the car from the boot)
A2307900404 (Right)
£63.50 each plus vat
Black Trim:
A2307920330 ( *Left) ( Very Long, back order, wait 6 months+)
A2307920430 (Right)
£62 each plus vat
The trim is of an updated design re- it's attachment, so a new mounting plate may be required.
All rest in stock
OP
OP
PhantomF4
PhantomF4
R230 Thulite Red
Mounting plates;
A2307900404 (Right)
Black Trim:
A2307920430 (Right)
£62 each plus vat
All rest in stock
My car is a 2007 model, am I right in thinking it will have the updated mounting plates?
John757
Surrey UK
I think if you look at the wider end of the trim piece, it has a small 'U' shaped protrusion.. this is one obvious point of difference.. you can see the same cut out in the mounting plate.. if you have this U shaped cut out, I don't think you need the Mounting plate.
Mercedes have apparently sold thousands of the replacement trims.. so you will have to see if your mount matches the one in the pic I posted here.
John757
Surrey UK
I plan to swap my trim in the next few days.. and will post pics of my old (cracked) one vs my new one.
Gbrowncls55
Surrey
CLS500 4.7TT 2012,, SL350 06, 996 cab, all current. Gone :CLS 55 E500 W211, 2x M5s and too many 911s
Given how many outside SLs suffer from this (mines the same) you would think a) they would have found a better solution by now and b) would always have stock available. My w218 cls had the same issue with the B pillar trims both of which i have now replaced. (parts came in two days)
John757
Surrey UK
Today I replaced my rear window side trim.
The reason I changed it was because it had an unsightly crack in it, which I missed when I bought it. The trims have not delaminated in any way like they have unfortunately on yours PhantomF4.
To remove the trim... you must have the roof half open, so you don't damage the rear boot seal. I have the special tool that holds the roof open, so I dont need to leave the engine on when replacing this seal.
Insert a plastic trim tool wedge 330mm from the top on the glass side of the trim
This will lift the plastic peg on the trim piece out of its hole, allowing you to tap the top of the trim gently with a block of wood and a hammer.. pushing the trim down and releasing all the catches holding it in place. below is a shot of the peg and its locating hole.
This peg is very important... it stops the trim piece sliding down when its fitted... if you do not lift the trim about 10mm at 330mm from the top of the trim it will not come off.
Trim removed.
The sticker on the underneath of the trim shows 19.10.14 which I assume is the date of quality control checks.. my car is a 2003 so it is safe to assume it has already been replaced before. because of delamination and the person who fitted it broke it in the process and glued it together and to the mounting plate where the break was with some kind of impact adhesive.
It did come off in one piece... however as it had been glued to the back plate the force of removing it broke off two of the moulded on retaining clips.. the very top appeared to have been glued too.. and its retaining lobe was missing.
I examined the mounting plate and compared it to my new one.. they are identical except for the slight recessed central bolt holes on the metal bracket.. so these have obviously been previously fitted in replacement of the original 2003 brackets. After a gentle clean I left my mounting plate where it was., no point in changing it.
The new Trim part it 100% black gloss plastic type material... and is obviously the updated part which since my old ones were replaced 12 years ago.. have not delaminated.
The many mounting clips moulded into the trim pieces hold it onto the bracket securely.
to replace align the trim so the top is about an inch from its final position and holding it evenly and pressing in firmly ..slide it up until it locks in place
The top and bottom of the trim has a more pronounced U shaped peg which locates in a similarly shaped slot top and bottom.
New plate sitting on old one for comparison
my old retained mount plate cleaned up
new trim fitted on
When refitting new trim there is no need to use the wedge (330mm down) because the peg rides along the mount plate then drops into its hole when it is in the correct position.
There is a need to use butyl rope to seal the mounting plate to the roof when the plate is removed. I have included the extracts from WIS for this procedure.
If your trims are delaminated... I have to guess they are original and not updated items and will need plates and trims.
I now have a spare n/s mount plate which I might consider selling.
  • Remove_install paneling on C-pillar upper section for Vario roof.pdf
  • Remove_install support plate for paneling on C-pillar upper section for Vario roof.pdf
OP
OP
PhantomF4
PhantomF4
R230 Thulite Red
View attachment 130404 View attachment 130406
Trim removed.
View attachment 130409 View attachment 130411
new trim fitted on
View attachment 130414 View attachment 130415
Thanks for the extremely detailed description and excellent photos John. I’ve a much clearer idea how this all works now.
Cheers
John757
Surrey UK
No problem.. I have learned from others how to do, boot seal, PSE pump etc.. If I can help another person.. the circle of comradeship continues...:)
