R230 rear 1/4 window sticking
magpie
The passenger side rear 1/4 window has been intermittently sticking of late in the closed position. Up until now this has been rectified by opening and closing the door window a couple of times and eventually it has worked. For the last two days it hasn't! When the door opens the window does not drop or move however this has not stopped the door from working. Also as it is stuck the roof will not open. Upon operating the roof the boot will open until the point the window is supposed to drop and then stop.
I have tried resetting the windows by holding the window switch for four seconds once the door window is closed but this has not helped.
Any suggestions here will be greatly appreciated.
Cheers
In my experience you have something in the mechanism that is worn or something is interfering with its operation. Stripping it down is probably the answer, but I realise this is not simple.
