R230 SL 2005, Drivers Electric Window Partially works
Vlad
Reading, England
Various Mercs come and go
Quick question to see if anybody has had this problem
I've got a 2005 SL350 and the drivers window wont go down when I press the switch. However, the window Auto Up function works correctly, ie when you open the door, the window drops a couple of mm's and jumps back up again when you close the door.
Is this indicating that i have a duff window switch, as I would have thought that if its the window motor/regulator the Auto Up function wouldn't work....any thoughts?
