R230 SL 350 knowledge
Discussion in 'General Discussion' started by SPX, May 16, 2019.
  1. SPX
    SPX MB Club Veteran
    15,807
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    Been offered a very very temptingly priced 2005 SL 350 by a friend of mine, it’s recently had rear springs done and comes with full service history but I was wondering is there anything I should be looking for that he might not be aware of himself? Wet boot for example?
    It doesn’t have ABC either, like nearly all 350’s.
  2. flowrider99
    flowrider99 Hardcore MB Enthusiast
    2,784
    Aug 25, 2011
    UK
    Car:
    SL500
    Some items to check on any R230/R231 SL.........
    1. Check the boot seal at the bottom of rear window as it tends to leak but there is a cheap fix for this. If the boot carpet is damp then I suspect the seal leaks.
    2. Check all 5 water drains are clear, 1 in the front at the base of the airbox (which is under the passenger side bonnet vent), 1 eon both c pillars and 1 at both ends of the boot seal.. Pull back the passenger carpet and make sure it is dry underneath, a wet or damp carpet indicates a blocked airbox drain.
    3. Check the roof operates smoothly, lower and raise it several times.
    4. Check all the electrics work.
    5. Make sure the PSE pump in the boot is dry, its under the boot floor panel on the nearside under a big sponge. If the sponge is dry then the pump should be dry.
    6. Check the rear wheel arches for rust. The inner arch lining allows crud to collect.
    7. Check the age of the consumer battery, this is the one in the boot. This battery runs all the electrics and has a hard life. The battery under the bonnet is only for starting the car.
    8. Cosmetic but essential, make sure the car has the wind deflector. These are quite expensive to buy and some sellers sell them separately which i think is a bit naughty.
    9. Check the gearbox goes from Park into Drive smoothly, these cars have a plastic linkage which can crack and break which results in being stuck in Park
    SPX likes this.
  3. OP
    OP
    SPX
    SPX MB Club Veteran
    15,807
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    Brilliant, thank you, I’ve been to look at it tonight and other than the head unit that cuts out, the basis of it is a good car.
  4. clk320x
    clk320x MB Club Veteran
    9,790
    Sep 27, 2016
    Midlands
    Car:
    W211 E320 CDI, W212 E250 CDI, W203 C32 AMG
    If you don’t end up buying it Lee please send me the details ;)
  5. DrFeelgood
    DrFeelgood MB Club Veteran
    8,781
    Nov 10, 2005
    Car:
    BMW 740Li
    Could you see yourself driving it?
    SPX likes this.
  6. OP
    OP
    SPX
    SPX MB Club Veteran
    15,807
    Aug 29, 2010
    Yorkshire
    Car:
    That one
  7. OP
    OP
    SPX
    SPX MB Club Veteran
    15,807
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    I took it for a blast up the road and I really enjoyed it actually, I’ve always loved the R230 and in my opinion it’s made every SL since look ungainly.
    And for the money he’s asking it’s a great bit of fun to run over the summer plus there’s no ABC to worry about...
    merc85 likes this.
  8. DrFeelgood
    8,781
    Nov 10, 2005
    Car:
    BMW 740Li
    I would.
    SPX likes this.
  9. OP
    OP
    SPX
    SPX MB Club Veteran
    15,807
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    For £5,500; it’d be rude not too, wouldn’t it?
  10. Merc220cls
    Merc220cls Hardcore MB Enthusiast
    368
    Feb 14, 2018
    Ayrshire
    Car:
    220 CLS Shooting Brake & 350 SL
    Enjoy it,
    I’ve just purchased a 2004 350 with just 8k since new, serviced, MOT’d and taxed every year.
    It’s like a new car and I just love it.
    SPX likes this.
  11. SL500AMG
    SL500AMG Hardcore MB Enthusiast
    1,727
    Nov 3, 2017
    GB
    Car:
    SL500 AMG Sport
    Hardly any of this applies to the R231, all issues resolved and a totally different SL.
    Sent from my SM-G955F using Tapatalk
  12. MD5
    MD5 Hardcore MB Enthusiast
    2,361
    Oct 15, 2008
    Car:
    wme451 a124 r129 s211 r230 w251
    SPX likes this.
  13. OP
    OP
    SPX
    SPX MB Club Veteran
    15,807
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    Had a bit of time to think about it and I’m going to pass on it - I got him down to £5,000 because of the headunit and a couple of other bits but it could just end up being something else I get bored of in double quick time then having to sell....
    MikeInWimbledon likes this.
  14. DrFeelgood
    8,781
    Nov 10, 2005
    Car:
    BMW 740Li
    RKG was an old
    Could your Mrs use a runaround?
  15. OP
    OP
    SPX
    SPX MB Club Veteran
    15,807
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    She’s got a runaround - a Toyota Hilux Invincible!
  16. DrFeelgood
    8,781
    Nov 10, 2005
    Car:
    BMW 740Li
    Does she have any friends?
  17. OP
    OP
    SPX
    SPX MB Club Veteran
    15,807
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    I’m confused - are you trying to sell me a car or give me advice?
  18. bob6600
    bob6600 MB Club Veteran
    5,667
    Jan 3, 2013
    Car:
    AUDI S8 V10, S210 E320 CDI (R.I.P.)
    I'm sure you can buy it, drive it for a couple of months and sell it for a profit or evens at worst. I guess it's more the time (and hassle) involved in selling it than anything else
  19. DrFeelgood
    8,781
    Nov 10, 2005
    Car:
    BMW 740Li
    Neither.
  20. flowrider99
    2,784
    Aug 25, 2011
    UK
    Car:
    SL500
    Looking over the list again I think about half are applicable to the R231
    SL500AMG likes this.
Share This Page
