Hey guys
Ive had the following issue today with the roof not opening due to the "close boot seperator " message being displayed although the separator is in the fully closed position.
After a little online research I have discovered that the micro switch is the culprit located in the boot where the boot seperator closes into drivers side
After shorting out the 2 pin connector the roof now opens fine however I’m not happy leaving it like this
I’ve opened the trim and exposed the PCB containing the switch
Has any replaced this micro switch before ?
I’ve found a similar micro switch online but am not 100% sure that it’s the same as spacing of the pins look slightly different
Link to similar micro switch I’ve found online
01055.2061-02 | SP-CO Button Microswitch, 4 A @ 12 V dc | RS Components 1
Any help would be much appreciated
I’ll give the dealer a ring tomorrow but I’m pretty sure they will sell this as a complete item only
Regards
Regards
