design guru
- Feb 28, 2004
- Location
- Hampshire
- 2001 W220 Mercedes S320cdi & 2001 W208 CLK230K (SORN since 2008)
I have a W202 C240 1998. I was running fine until the water pump began leaking so I replaced the water pump successfully and now when I start the car the radiator fan in front of the engine runs at full speed continuously.
I was not doing this before, the only issue I did have after replacing the pump was the battery had gone flat after I left the boot open whilst changing the part and the interior light must have drained the battery and it had not been run for 2 days.
I charged the battery fully but the fan still runs at full speed as soon as the car is started. The engine is cold. Anybody have similar issue and found the cause?
