Radio
QUTSELL
Langdon Hills Essex
Mercedes C180
Radio straight to the point. Speaker n/s ok , bugger all sound on drivers side from both , I guess answer is door panel off ?.
I suppose you have gone into the settings for the audio in your car,the r/h speaker might have been turned off by accident ? :D
  • Like
Reactions: 219
The drivers door is usually the one that is opened and closed most - unless it was a taxi once - so if a speaker wire was going to break it would be there I am guessing.
Zidip. Thanks for reply. Please can you let me know what and were, cannot find any info in the book.
Well if you have command fitted to your car you can alter the sound coming out of the speakers. it is in audio balance and fade,the fade is if you want the front speakers to be louder than the back ot the other way around.
If you do not then maybe take the door trim off bot the front doors and swap the speakers,it may be that one speaker has blown,and so all you would need to do buy a speaker
Thanks Zidip will do, but there is no sound coming from the speaker on the top of the door, so I will pull of panel and check wiring.
The tweeters on mine had blown. They are very easy to replace and shouldn’t cost much.
What about rear speakers ?
Are they working left and right in the back ?
If not , this points to the balance setting in the radio .
If only the front right not working then it just might be the speaker , or a wiring fault .
PS I got the radio linked to my phone, after days of trying and re trying up comes the numbers on my phone to link, put same numbers into the radio, bingo, although why it connected is anybody's guess, one job sorted, now the speaker.
I will get madam to sit in the back and try that, thanks for help.
