Just noticed a 'pond' of rainwater between the upper engine bay and the windscreen base where the windscreen wipers are connected, there is a plastic grille there which is supposed to drain the water but is evidently blocked ... I tried pushing in a thin skewer but can't locate the actual discharge hole/tube which may be blocked by old leaves,etc.
Any idea where the outlet of this area discharge is or where exactly is the hole under the grille to try clearing with stiff wire?
