^^^X2 I wonder whether the bonnet insulation pads are still available from MB? Bodywork and sills seems to be in good order which is a positiveNice enough example but a few things I noticed:
Mileage isn’t genuine, check the MOT history. Crack in the RH trim panel in the dash is where the instrument cluster has been out
Regarding the smoke, would need diagnosing. I suspect the exhaust valve guides have worn, and the engine would probably benefit from a top end overhaul. The bottom ends of these engines are pretty durable.
Guy seems keen enough, but clearly doesn’t know a lot about these cars which is a shame. Sad to see he’s planning on taking a pretty original looking car and modifying it with non original suspension/wheels/exhaust etc.
To me I’d do a compression and leakdown test and probably have the head off to overhaul it properly. New timing chain, new engine mounts (you can see they’ve gone with the engine running and the exhaust moving around!), bonnet insulation pad, repair the bolster and lap timer, trim panel on the dash etc, sort the wobbly aerial out, clean and wax everything underneath and get it detailed.
But I guess we’re all different!
The rear jacking points have had it. They don’t look too bad on the outer sill but it will definitely be one of those repairs that gets more involved once you start. They fill with water and rot from the inside out^^^X2 I wonder whether the bonnet insulation pads are still available from MB? Bodywork and sills seems to be in good order which is a positive
Nice guy he is. I think he will really appreciate the spare parts and advice. I have attended a few meets, the last one was Benz with Friends which was a good turn out. The other club members turned up too.The rear jacking points have had it. They don’t look too bad on the outer sill but it will definitely be one of those repairs that gets more involved once you start. They fill with water and rot from the inside out
Not sure on the bonnet pads, there’s various types. Were available from MB a few years back though. I know you can buy aftermarket ones anyway so that’s always an option too.
I actually pass by where this guy is based quite regularly, maybe I should pop in and offer some advice
I have a spare VDO stopwatch and new LCD screen, that might help him out too
Give my regards to Raj, they'll know my car when you mention
Not a 190e but I got a new bonnet pad for my W124 from Mercedes Newcastle on ebay. £96 inc. delivery.^^^X2 I wonder whether the bonnet insulation pads are still available from MB? Bodywork and sills seems to be in good order which is a positive
