design guru
- Feb 28, 2004
- Location
- Hampshire
- 2001 W220 Mercedes S320cdi & 2001 W208 CLK230K (SORN since 2008)
I have a strange problem with my 2001 W220 s320cdi, if I jack the car up for a while the front struts loose some pressure and when it drops it looks pretty low, I can start the car and press the lift button but nothing happens, it only starts to lift and level itself when the car is moving. I just leave the switch is rise position and eventually it just levels itself. It seems the pump works but only when the car is in motion
I have a iCarsoft MBV2.0 and it did flag an error with the acceleration sensor, but would this would fix the problem with the pump not running when the car is standstill. Before I could use the button and the car would rise and go down when switched on/off whilst the car was in park.
Has anyone had any similar problems and found the acceleration sensor was the culprit?
