So I've done close to 600 miles in my new E300 Hybryd and wanted to share a few thoughts about it and also ask a few questions.
I would appreciate if you share your thoughts and answers
- Is it just me or is the gear lever counter intuitive to use? I feel like pressing forward should be Drive and pulling backwards should be reverse, but it's the other way around. It still takes me 1-2 seconds sometimes to figure out which way I need to press.
- Why are the wheels spinning and the car being jerky when I accelerate harshly when the car is cold? Same thing on my Honda Civic 8th gen. Traction control? Abnormal behaviour?
- My Civic has a dedicated button for heating the side mirrors. Is this integrated in the back window heating button on the Merc or it just doesn't have it as an option?
- Is it normal for the DAB radio to cut out from time to time? It feels like it is losing connection or something.
- Mercedes said they will update my Navigation map for free as the car is still under warranty. Anything else worth updating, so I ask them?
- There is also some recall and was told some liquid needs topping up. Any info on that?
- Why is the reverse camera so bad? The side and front too. During night time you can barely see anything as it is so dark and the brightness is set to maximum. A friend got a prius and his reverse camera is so much brighter and you can actually see things around you quite clearly. Any way I can increase the camera sensitivity?
- Can the 360 camera system can somehow be hacked to be used as a dashcam and record while driving? Or even better record if the alarm goes off?
- The steering wheel squeaks quite loudly when the interior is cold. It sounds like the rubber housing is rubbing against some plastic and it's very annoying. Any fix?
- I think I have what is called a Multicontour seat with air chambers, but this is only on the drivers side. I have seen other cars that have it on both sides, which makes me wonder why I don't have it on the passenger side.
- I got folding rear seat and under the central arm support there is a small hatch that can only opened from the boot. What is the logic behind that? I find it more practical to be able to open it from inside the cabin or even better from both sides.
- I got 2 unknown buttons on the roof - one shows a car with some signal level and the other a car with a hook. Any idea what are these for?
