rapid flashing indicators
adehook
vito 109
as above, really,
checked the bulbs they seem fine, it does it on both sides as if theres a bulb gone, the hazards work normal, on a vito 109
thanks
ure situation in most cases would indicate a bulb blown/faulty but you say both sides which must only mean that the indicator stalks are faulty to a certain extent if you say the hazards work fine since they run through a seperate switch.
I would look at the relay if the bulbs are ok.
