Saw this today - very rare I think?
Aston Martin DB5 Shooting Brake, badged 'Superleggera' on the bonnet.
Superleggera bodywork is notoriously easy to dent. Sneeze near enough to it and you will make an impression - and not the sort which the owner would be greatly pleased either.
The aluminium sheet is very thin - formed over a steel tube structure.
I think all DBs up to the 6 used this method, IIRC.
Lovely motor, though. Different. Truly a rose twixt two thorns in that picture...
The David Brown built Shooting Brake" is one of the rarer Astons, but the rarest is the DB4GT Zagato of which only 19 were built..:bannana:
The Radford built Shooting Brake" is one of the rarer Astons, but the rarest from the factory was the DB4GT Zagato of which only 19 were built..:bannana:
Let me compliment you on your mastery of understatement.Not as easy to dent as you would think.
"Superleggera" ( Super Light ) was a term coined by Touring of Milan who developed the skin over tube construction.
Touring licensed the method to AM for use in the DB4, DB5, DB6 builds.
The dissimilar metals ( aluminum over steel tube ) caused a bit of galvanic problems...
Only 7 of these were built (or at least, sold), apparently. Used to see one quite often parked in Berkeley Street.
I don't believe it was badged an Aston Martin but a Lagonda...
David Brown, who had loved the name Lagonda, showed great enthusiasm when a new one based on the Aston Martin DBS was visualized in 1966; the go-ahead was given in 1968... They called it the Aston Martin Lagonda, and it was given a modified series three V8-style front and a carburetter engine. Seven were made between November 1974 and the time of Company Developments' demise at Newport Pagnell, some being finished while under the receiver. The price was £15,638 including tax - nearly £3000 more than an Aston Martin V8 at that time.
