rattling over small constant bumps.
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by OneForTheRoad, May 6, 2015.
  1. OneForTheRoad
    OneForTheRoad MB Enthusiast
    2,373
    Apr 20, 2015
    uk.
    Car:
    2015 w204 c class amg sport premium +65 ford kuga 2.0 cdi zetec awd..
    are any of the suspension parts common /easy to identify lads for wear and tear . im getting a rattle over small bumps , nothing on flat roads or over speed humps, ( silent ) only seems there on longish stretches of small bumpy road / pot holes etc .
    much obliged for any help .
  2. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    Could be that your brake pads are not a perfect fit. Aftermarket ones especially can be slightly too small for their carriers and as the wheels shake over the surface they shake in their carriers.
    If you go over cobbles to produce this sound, with your brakes slightly on, if it silences the rattle, it'll confirm it's the pads. If the sound remains with the brakes lightly applied, then it's not the pads...
  3. guydewdney
    guydewdney MB Enthusiast
    2,903
    Feb 14, 2004
    Porlock, Zomerzet
    Car:
    906 Sprinter 313cdi
    Lower front wishbones? Easy to identify on a ramp. W211 ones from online retailers about 25% of mb price
  4. Jonesy161
    Jonesy161 Active Member
    228
    Apr 6, 2015
    Car:
    W204 c220 sport
    Don't know the set up on your car but I've had similar noises/ conditions on cars with drop links failing.
  5. carat 3.6
    carat 3.6 MB Enthusiast
    3,923
    May 11, 2011
    Buckinghamshire, yuppie central 1985.
    Car:
    96 e300d, 88 w124 superturbodiesel, 90 bmw E30 v8, + "others"
    I'll second drop links.
  6. rusty55
    rusty55 Active Member
    178
    Jul 24, 2014
    wiltshire
    Car:
    sl320
    My r129 turned out to be disc pads with the very same symptoms but the rattle does happen slightly now and again
  7. guydewdney
    2,903
    Feb 14, 2004
    Porlock, Zomerzet
    Car:
    906 Sprinter 313cdi
    Is this 210, 211 or 212?
  8. Tim203
    Tim203 Active Member
    402
    Sep 17, 2014
    I'll third drop links. Anti roll bars are under no load until the wheels are moving in opposite directions.Small bumps find all the play in the ball joints. Who invented these things anyway, rubbish idea that's produced yet another 'service item'
  9. OP
    OP
    OneForTheRoad
    2,373
    Apr 20, 2015
    uk.
    Car:
    2004/w211 m8.
  10. OP
    OP
    OneForTheRoad
    2,373
    Apr 20, 2015
    uk.
    Car:
    im beginning to think this is the under belly trays rattling on the chassis . a few cable ties here and there might of silenced it a bit . hopefully ....
  11. E270 Owner
    E270 Owner MB Enthusiast
    1,672
    Dec 23, 2012
    S E London
    Car:
    Anything I get my hands on.
    Don't mess around with suspension and steering ........ get it checked professionally.
    :thumb:
  12. gIzzE
    gIzzE MB Enthusiast
    5,642
    Jan 20, 2004
    Norfolk, UK
    Car:
    530d Touring + ML270 Inspiration
    Lie under the car and wobble the anti roll bars, tap them hard with the palm of your hand, if there is any sort of play at all they need replacing.
    They are like butter on mercs.
  13. OP
    OP
    OneForTheRoad
    2,373
    Apr 20, 2015
    uk.
    Car:
    are they easy changed gizze ?
  14. OP
    OP
    OneForTheRoad
    2,373
    Apr 20, 2015
    uk.
    Car:
    both rear exhaust heat shields broken off their fixing points - been rattling on rear silencers - wedged for now with some foam , until I can maybe pop rivet them back on somehow . result - no more rattling and free of charge a fix .
  15. a111r
    a111r MB Enthusiast
    1,612
    Aug 11, 2008
    North East London
    Car:
    S123 240TD, S210 320cdi, S202 250TD.
    I don't think back boxes on diesels get anywhere near hot enough to warrant a heatshield.
    When one of mine broke loose, I removed it.
  16. OP
    OP
    OneForTheRoad
    2,373
    Apr 20, 2015
    uk.
    Car:
    im going to get 2 big washers and attach them over the original fixing pegs with araldite and silicone - once set with the foam in place they should hold in place again .
Share This Page
