chesterpiglet
- Oct 8, 2008
- Mercedes W211 E280 Cdi Sport Estate
Hi all
Now that the cold weather is here my gearbox doesn't appear to like it!How do I check the fluid?I have a good look around the engine bay so I presume it is done from underneath?
The box appears to work well from cold-it just makes a strange noise.It feels as though the box is struggling to disengage when there is no depression of the accelerator,or when it is stationary and particularly in reverse there is a vibration as well.This sympton is most noticeable if I go around a right hand bend(ie the front left tyre is under load)and if I go over a speed bump as the front wheels bump over the other side.
The car has quite a high mileage(206K)with FMBSH to 169K but independant after that(and a few bodges as well).
I suspect this fault was why the car was P/X'd.
So long as it doesn't get any worse I will leave it as it is(I would like to change the gearbox fluid though).The symptons disappear when the car is hot after 5-6 miles.It does groan a bit around 40mph as well.
Any suggestions would be gratefully received.
Many thanks
Regards Rob
Many thanks
Regards Rob
