Re:Injector seals
chesterpiglet
Mercedes W211 E280 Cdi Sport Estate
Hi
Could anybody tell me how to remove the injectors on my 1997 E300? Do I need a special tool to remove them and is there a procedure to do so or any other tips?
Manyn thanks
Rob C
Remove the black plastic cover over the rocker cover. 8 x 5mm bolts. Unfasten injector feed lines 14mm. remove the leak off pipes ( the braided rubber ones) from the injectors. Using an extra long 28mm socket unscrew the injectors ( you may need to purchase one of these that is made for the job ) Job done.
Hi there
Many thanks for the advice.How deep does it have to be exactly?
Would you or anybody know of a place where I could buy one of these online?
Thanks again
Regards rob
